May 6th, 2024, 6:04am
Reduced simulation speed of 'only analog' blocks in cadence AMS Vs Spectre (Read 1854 times)
ananya
May 30th, 2016, 7:57pm
Hello!
I am simulating a continuous time sigma delta ADC in cadence virtuoso and AMS environment. I am trying AMS simulator  as i am going to add a few digital blocks on the go. However, i noticed that the same schematic runs too slow with an AMS environment.This is the case, if i operate the ADC with a dual supply. With a single supply, simulation speed is equivalent in both.
Could anyone suggest something?
With regards,
Ananya
ananya
Re: Reduced simulation speed of 'only analog' blocks in cadence AMS Vs Spectre
Reply #1 - May 30th, 2016, 11:10pm
I found out the issue. In the view list of config view, my default order was veriloga,..., schematic. There were a few veriloga blocks in the system which were getting preference over schematic. In the veriloga model, 0 and 1.8V numbers were mentioned. This was causing problem when I used dual supply(+/-0.9V).
But, spectre, by default choses all schematic views.
