Apr 29th, 2024, 5:17am
connecting Current starved VCO and TSPC divider (Read 2860 times)
geeksy
Jun 24th, 2016, 3:17am
Hi..! I am designing a PLL, i have a problem when i connect VCO and the divider(TSPC). i have some fluctuations in VCO output when i connect it with divider.  i tried connecting inverter buffer in between but it is not working too.. i cant trace out what exactly the problem is..? i think its because capacitance of TSPC (true ?).. how should i solve it.?..
I need your help Cry
Thanks..!!
vroy_92
Leuven, Belgium
Re: connecting Current starved VCO and TSPC divider
Reply #1 - Jul 20th, 2016, 3:09am
What is the fluctuation you are talking about? Frequency is off? Then it is probably due to the capacitance. Voltage waveform is showing sudden spikes? Then it is probably due to kick-back or something else.
V Roy
geeksy
Reply #2 - Jul 20th, 2016, 3:13am
Thanks for the reply,
i have sudden voltage spikes, can you give some details about kick-back..?
vroy_92
Leuven, Belgium
Reply #3 - Jul 23rd, 2016, 1:28am
Lets say you your VCO is driving an inverter. When the output of the inverter is switching, through the Cgd cap, it will couple back to the input. The similar thing is happening to your case as well.
You cannot reproduce this by driving an inverter with an ideal pulse voltage source. You need to connect a source resistance in series.
You can think of connecting an isolating inverter between the inverters in your ring and the TSPC divider.
V Roy
