Apr 25th, 2024, 5:55pm
Meaning of PAC (Read 3025 times)
designer_dude
Meaning of PAC
Aug 02nd, 2016, 10:56am
I am running PAC, in the default mode for a Time Variant Periodic system.  When I plot the output of PAC for particular nodes, I get a set of function labelled by the pss harmonic  (call it n).  Those functions are plotted from range$ n*f_{PSS} to n*f_{PSS} + f_{sweep}$  where $ f_{sweep}$ is the sweep range.  How are those curves related to the transfer function $H_n(f)$ that completely characterize an LTV periodic system in the derivation attached?  If they are not related, what is the mathematical definition of the pac output curves?
Thanks!
Re: Meaning of PAC
Reply #1 - Aug 2nd, 2016, 4:48pm
They are the transfer functions. In other words for the nth sideband, the result computed by PAC is the output voltage at n×fPSS + fin where fin is the analysis frequency. If the input source has pacmag=1, then the result is the transfer function from the input source at fin to the output at n×fPSS + fin.
designer_dude
Re: Meaning of PAC
Reply #2 - Aug 2nd, 2016, 4:54pm
Thanks Kent for the reply.
Why is then the "support" of the transfer function (also called range) plotted only from n*f_pss and not 0 frequency for the transfer function labelled with n?
When I plot G_n(f), which I define to be the gain from f_pacsource to f_pacsource + n * f_pss, I expect the "support" or the frequency range to be from 1k->10G or whatever I defined in the sweep.
Like G_5(1kHz) for f_pss = 1MHz would be the gain from 1kHz pac modulation to output of 5.001MHz.  This should be defined for 1kHz -> infty ideally.
Re: Meaning of PAC
Reply #3 - Aug 2nd, 2016, 6:54pm
That is under the control of the freqaxis parameter.
