Jul 27th, 2024, 3:29pm
Nested loop stability requirement (Read 980 times)
thomasross20
Aug 19th, 2016, 4:36am
I know there are other topics touching on this but I never saw a definitive answer.
If I have an amplifier with one master outer loop which is stable... and one inner loop... does the inner loop need to be stable or not?
References and hand-waving explanation much appreciated!
Thanks..
Frank Wiedmann
Munich, Germany
Re: Nested loop stability requirement
Reply #1 - Aug 19th, 2016, 5:37am
No, the inner loop does not need to be stable. You can have a system that is open-loop unstable but closed-loop stable. See http://www.designers-guide.org/Forum/YaBB.pl?num=1294178255 for an example.
Reply #2 - Aug 23rd, 2016, 10:42am
Last I checked, stability is only a question for those systems in which feedback exists.
No?
Think about it.
Frank Wiedmann
Munich, Germany
Reply #3 - Aug 24th, 2016, 12:18am
"Open-loop" refers to the outer loop. Of course, the inner (unstable) loop is still closed.
thomasross20
Reply #4 - Aug 24th, 2016, 10:59am
Thanks - I will check out the link you posted.
FYI I have an inner loop and an outer loop which is closed.
So you can have a system which is closed-loop stable (main outer loop) and have internal loops that are unstable... I never did manage to find a good paper on this. I'll check out the link..
