thomasross20
Thanks - I will check out the link you posted.
FYI I have an inner loop and an outer loop which is closed. So you can have a system which is closed-loop stable (main outer loop) and have internal loops that are unstable... I never did manage to find a good paper on this. I'll check out the link..
