Jul 21st, 2024, 7:15pm
Disable updating DefValue of CDF Parameter from Verilog-A in Cadence IC6 (Read 1423 times)
cheap_salary
Sep 15th, 2016, 8:23am
DefValue of CDF parameters are updated from "parameter statement" in Verilog-A everytime I save Verilog-A code in Cadence IC6.
However this operation is troublesome.
DefValue of CDF parameters were not affected at all in Cadence IC5.
Is there any method to disable this operation in Cadence IC6 ?
parameter real Tari = 6.25u from [6.25u:25u];
parameter real Delimiter = 12.5u from [0.95*12.5u:1.05*12.5u];
parameter real Tsymb_0 = Tari;
parameter real Tsymb_1 = 2*Tari from [1.5*Tari:2*Tari];
parameter real RTcal = 2.75*Tari from [2.5*Tari:3*Tari];
parameter real TRcal = 2*RTcal from [1.1*RTcal:3*RTcal];
parameter real Tpw = 0.5*Tari;
parameter real tt = 0.33*Tari from (0.0:0.33*Tari]; //transition time of output
