Jul 26th, 2024, 3:20am
Pierce oscillator not oscillating problem (Read 1649 times)
YUJIN
Oct 17th, 2016, 12:46am
hello
I am designing crystal pierce oscillator using cadence simulation tool
With specification, 32.768kHz(AB26T)
Below is my design.
I used for 10nA current for inductor initial current
But the oscillation decreased and not started.
1. Is this because inverter gain problem?
2. Also, how inverter can operate as amp? i think one of mos will go triode region, right?
deba
Re: Pierce oscillator not oscillating problem
Reply #1 - Oct 18th, 2016, 2:57am
It could be the gain provided by the inverter is less. What is loop gain you see?
An inverter if biased in the steep transition region can provide linear amplification.
