Apr 29th, 2024, 3:59pm
High-Vt (Read 1147 times)
asorab
High-Vt
Nov 06th, 2016, 11:20am
Howdy people! How to implement High-Vt mos in TSMC 0.18um tech?
kemiyun
Re: High-Vt
Reply #1 - Nov 6th, 2016, 9:06pm
It's been a while since I've used 0.18um but there should be a separate model most likely named nmos_hvt or something, I even forgot the naming convention unfortunately. But in the process documents there is actually a list of available devices which is exactly what you should read. It will also direct you to the correct models you should use for the device you want to use high Vt device in this case.
If you mean to ask how they're implemented in layout, there's actually a layer that specifies the Vt of devices as far as I remember. Again refer to device truth table for the name of the layer.
If you're asking how the Vt is adjusted, that's not my expertise but as far as I know ion implantation is the most commonly used method, you can read more about it online.
vroy_92
Leuven, Belgium
Re: High-Vt
Reply #2 - Nov 7th, 2016, 10:48am
I think it will pch_hvt_mac or nch_hvt_mac.
V Roy
asorab
Re: High-Vt
Reply #3 - Nov 10th, 2016, 3:23am
Thank you for your response guys. I highly appreciate it.
asorab
Re: High-Vt
Reply #4 - Nov 19th, 2016, 9:33am
I use nmosvt2v and pmosvt2v but it shows error. It says "model name is missing..".
Abdullah
Re: High-Vt
Reply #5 - Jan 1st, 2017, 9:56am
Are you getting this error while simulating your circuit? if so, add the mos.scs to the ADE model library.
A.D.J
Re: High-Vt
Reply #6 - Jan 3rd, 2017, 1:16pm
You can check the TSMC 0.18um PDK folder. There is a doc folder including the model description file. The list of MOSFETs provided by the PDK should be written.
adj
