May 2nd, 2024, 8:06pm
clock voltage doubler (Read 3194 times)
liletian
MD
Nov 07th, 2016, 10:53am
Hi Guys
I had a clock with voltage swing of 0 to 1.8V. I would like to generate a clock with voltage swing of 0 to 3.6V. I knew it can be generated a clock with 1.8V to 3.6V.
The supply voltage is 1.8V.
Can anyone share some ideas? I am not sure if there have an relative easy way to do it.
Thanks a lot
deba
Re: clock voltage doubler
Reply #1 - Nov 10th, 2016, 5:23am
Cann't you pass it through a level shifter which operates from 3.6 V?
nrk1
Reply #2 - Nov 21st, 2016, 5:19am
Use a level converter supplied by a voltage doubler.
subtr
Analog Enthusiast
India
Reply #3 - Jan 6th, 2017, 6:02pm
There is something called Nakagome Charge Pump used in ADC's for the sample and hold switches. This video by Prof. Shanthi Pavan IIT Madras. The clock generated is not 2Vdd to zero, but 2Vdd to Vdd. But given you have 2Vdd voltage, you can drive an inverter using 2Vdd supply. But the catch is that if your inverter is taking huge current, then your Cap sizes will go up. This is just like any other switched capacitor circuit. We can interpret the current pumping capability to the impedance of the source which depends on the frequency of switching and the capacitor.
https://youtu.be/8yo42AFczvo?list=PL2135D8A0F7441AE1&t=1950
Subtr
