May 1st, 2024, 7:29pm
Verilog A for IP encryption (Read 2539 times)
engrvip
Nov 19th, 2016, 5:41pm
Hi
My requirement is that i want to encrypt my analog IP say opamp before sending to external customer for simulation with his system.
Can VERILOG-AMS help me in thi application. Or is their some other way to achieve this kind of functionality.
Vipul
Re: Verilog A for IP encryption
Reply #1 - Nov 21st, 2016, 5:10am
Verilog-AMS does not have encryption in the standard.  There was a company that allowed you to deliver compiled Verilog-A modules to customers to provide some level of IP protection; however, Tiburon was acquired by Mentor (which may be acquired by Siemens), so I don't know the status of that feature.
Reply #2 - Dec 29th, 2016, 11:19am
Various simulators (such as Cadence AMS Designer and Spectre) do support encryption (e.g. using ncprotect or spectre_encrypt - I think that's the tool name from memory; I don't have access to the software right now) - other simulators do too. However, these encryption methods will only work within the same family of simulators (so you couldn't expect Cadence encrypted data to work in Mentor or Synopsys simulators or any other way around).
