Apr 28th, 2024, 3:15pm
Access bits of integer (Read 1649 times)
Gornarok
Dec 11th, 2016, 9:44am
Id like to make a modul that has integer as input and outputs its value as bits. Is it possible to access bits of integer? Or can I converse integer to bit vector? What would the best way to do it?
I wanted to do something like this:
analog begin
	generate i (fN-1,0)begin
		V(filter_out[i]) <+ filter_in[i] ? V(vdd): V(vssr);
	generate i (gN-1,0) begin
		V(gain_out[i]) <+ gain_in[i] ? V(vdd): V(vssr);
Re: Access bits of integer
Reply #1 - Dec 13th, 2016, 5:38pm
The easiest way to do this is to do a bit-wise and. So something like:
generate i (gN-1,0)
    V(gain_out[i]) <+ transition(gain_in & (1 << i) ? 1 : 0, 0, 1u) * (V(vdd) - V(vssr)) + V(vssr);
Use of the transition function is also important.
Use of genvars is now preferred over use of the generate statement, so you should probably use:
genvar i;
for (i = 0; i < gN; i = i+1)
