Apr 29th, 2024, 12:30pm
sub-threshold design of MOSFET for 45nm technology (Read 1979 times)
joy
Bengaluru
Dec 17th, 2016, 9:46pm
I want to design a op-amp for 45nm technology which is operating in sub-threshold region
can any one give me the ID and gm equations which can be used for hand calculations in BSIM3 model, i am using a cadence virtuoso simulator .
Thank you
lpalocko
Re: sub-threshold design of MOSFET for 45nm technology
Reply #1 - Jan 27th, 2017, 3:56am
why do you want to use exactly the BSIM3 model?
LP
Reply #2 - Jan 29th, 2017, 1:01am
The model equations are documented in the MMSIM documentation - if you invoke <MMSIMinstDir>/bin/cdnshelp you'll find it under the "MMSIM" section in the documentation (I can't remember the manual name off the top of my head, but it's got something like Model Equation Reference in the title). There's a chapter on bsim3v3 and another on bsim4. Most likely any 45nm PDK (such as the Cadence Generic 45nm PDK, gpdk045) will use bsim4, not bsim3v3.
Andrew
