May 3rd, 2024, 9:03pm
Emitter follower for bandgap reference (Read 2556 times)
blue111
Jan 06th, 2017, 8:19am
how to prove both circuits topologies below (series diode and emitter follower) are equivalent ?
Both PNP transistors should have same current densities shown below with the same Vb on both PMOS load.
subtr
Analog Enthusiast
India
Re: Emitter follower for bandgap reference
Reply #1 - Jan 6th, 2017, 5:24pm
Both the circuits might be producing equal voltages. But the looking in DC incremental impedance should be different for both circuits. In fact the first one would have 2/gm and the second one would have 1/gm. This means that if we had a capacitance in the output node, the first one would halve half the bandwidth of the second one. Probably we can see the 2x current in the second one as a reason to get this extra bandwidth. In Bandgap you might be more worried about the feedback amplifier's poles than this pole though.
Subtr
blue111
Reply #2 - Jan 8th, 2017, 11:37pm
I understand your concern regarding this pole placement due to 1/gm. However, I still could not understand how both circuit tolopogies end up with same voltage that is 2Vbe
subtr
Analog Enthusiast
India
Reply #3 - Jan 9th, 2017, 2:07am
An emitter follower shifts the voltage up. Do you agree? A resistor shifts the voltage up. Do you agree? Do I now tell both are doing the same job hence both are equivalent? The diode connected transistor is equivalently a resistance of 1/gm.
Subtr
