Apr 27th, 2024, 11:49pm
Deriving Gm of circuit (Read 10123 times)
blue111
Jan 09th, 2017, 12:15am
For the following LC filter implementation,
I understand that this is a gyrator, but how to relate the two accuracy knobs (<7:0> and <2:0>) to the resonance frequency ?
Resonance frequency = 1/[sqrt(Leq*Cs)]
Leq = CL/(Gm1*Gm2)
In other words, how to derive equation for Gm2 in terms of the two accuracy knobs ?
subtr
Analog Enthusiast
India
Re: Deriving Gm of circuit
Reply #1 - Jan 9th, 2017, 2:17am
Your amplifier is a source degenerated amplifier. So the actual Gm is gm/(1+gm.Rs). Now the gm is a function of current, W/L of your transistor. I hope you have the handles. If you want to increase Gm, increase current or reduce the Rs. As you see both vary Gm in different fashion and have different effects. Increasing current would look easy, but it will affect your current source's bias margin reducing CMRR. Increasing current will reduce the gain. But varying Rs will not give you a great range, but will not affect your dc operating much as it carries incremental current.
Subtr
deba
Reply #2 - Jan 9th, 2017, 9:53pm
The Gm2 for the bottom transconductor is given by gm6/(1+gm6*Rs/2). Assuming that M6 and M5 are same. I have neglected gds and other contributions while deriving the expression. gm6 is a function of the bottom current source and Rs is the tunable resistance.
blue111
Reply #3 - Jan 16th, 2017, 3:43am
1) I am not sure how you derive Gm2 without considering the impedance looking into the drain of M4 or M3.  http://whites.sdsmt.edu/classes/ee320/notes/320Lecture32.pdf
2) Besides, I was told that the tail current is a coarse accuracy knob, while the degeneration resistance (Rs) is a fine accuracy knob.
Any insights ? Thanks!
blue111
Reply #4 - Jun 24th, 2017, 6:31am
@subtr :
Could you elaborate more on your statement above possibly with some other references, diagrams or equations ?
blue111
Reply #5 - Sep 13th, 2017, 12:53am
For transconductance value of CMOS inverter, is it normal to be very small value ?
Reply #6 - Sep 14th, 2017, 7:25pm
You should be able to turn the block into an oscillator, reverse the inputs
to generate positive feedback. Then run transient simulation and look at
the frequency of oscillation. You know the frequency and the value of C,
calculate Gm.
Horror Vacui
Dresden, Germany
Reply #7 - Sep 21st, 2017, 10:45am
gm is a small-signal parameter. It depends on your operation point. I have doubts whether the OP was set correctly.
If you have the DC transfer characteristic of the inverter, than you have the gm as well. gm is its derivative.
Sheldon's suggestion is also good, but oscillation is usually large signal. So you will get some kind of gm average of the "operation points" traveled through during oscillation.
Reply #8 - Sep 22nd, 2017, 3:33pm
In general, if the gm stage is capacitively loaded, then the input voltage
should be Output Voltage Excursion/ open loop gain at frequency. So,
the effectively signal levels for the input devices should be small.
In general, the gm of a gm-C filter stage has some method of fixing the
gm to a constant value across the operating range. If it isn't then there
is distortion, that is, the gm changing as a function of input signal level
causes limits the dynamic range of the stage. The function of the source
degeneration resistors in the original schematic is region where the gm
in constant.
RickyTerzis
Reply #9 - Sep 26th, 2017, 10:31am
Hi...i am a new user here. As per my knowledge the gm is a function of current, W/L of your transistor. I hope you have the handles. If you want to increase Gm, increase current or reduce the Rs. As you see both vary Gm in different fashion and have different effects. Increasing current would look easy, but it will affect your current source's bias margin reducing CMRR. Increasing current will reduce the gain.
blue111
Reply #10 - Sep 29th, 2017, 3:44am
As shown in the screenshot below, G-parameter two-port model is suitable for the active inductor made up of  voltage-voltage feedcback mechanism.
Please correct me if I am wrong.
I am planning to use G-parameter to measure the inductance value created using this gyrator circuit.
« Last Edit: Sep 29th, 2017, 10:30pm by blue111 »
blue111
Reply #11 - Jan 30th, 2018, 7:25am
In ngspice, .OP gave me the following:
I am looking at it now. Does anyone have any comment ?
Quote:
Initial Transient Solution
Node                                   Voltage
x1.in                                  2.09899
vout                                         0
vdd                                        3.3
vss                                          0
vtest                                        0
gm2.in                                     1.8
xgm2.g3                                2.14857
xgm2.1                                     3.3
gm2.out                                2.09899
xgm2.2                                     3.3
xgm2.5                                     1.8
xgm2.4                                0.649101
xgm2.6                                0.649101
xgm2.8                                0.649101
xgm2.9                                0.649101
x1.out                                     1.8
v_ip_gm2#branch                              0
v_ip_x1#branch                               0
v.xgm2.v_ip3#branch                      4e-05
v.xgm2.v_ip4#branch                      4e-05
v.xgm2.v_ip5#branch                      4e-05
v.xgm2.v_ip6#branch                      4e-05
v.xgm2.vb#branch                             0
vtest#branch                                 0
vs#branch                           0.00280043
vd#branch                          -0.00280043
I am stucked at getting this active inductor https://github.com/promach/frequency_trap/tree/development working.  Could anyone help ?
I will proceed to S11 parameter check afterwards if things still stucked.
