Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 14
th
, 2024, 8:47am
Home
Help
Search
Login
Register
PM to admin
Measurements
Other Measurements
› Noise considerations in Testing of High-resolution Signal Acquisition system
Previous topic
Next topic
Noise considerations in Testing of High-resolution Signal Acquisition system (Read 2418 times)
jdp
Jan 11
th
, 2017, 10:44pm
Hi.
For testing of an integrated high-resolution Signal Acquisition system, intuition tells that one should employ a signal generator (to feed the i/p test signal to the system) having very low noise of its own.
Is this indeed how the performance of such high-resolution (~20 bits) acquisition systems are measured? ( I need to measure the o/p SNR)
Are such low-noise signal generators at all available?
Any idea in this regard is highly appreciated.
Thank you.
-- jdp
IP Logged
deba
Re: Noise considerations in Testing of High-resolution Signal Acquisition system
Reply #1 -
Jan 13
th
, 2017, 12:19am
Hi
As far as I know, such generators are available. But if it for testing purpose, there are very sharp band-pass filters available for various frequencies, which can be used to further clean up the signal generators.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
»» Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
