Dec 17th, 2025, 6:07pm
power spectral density simulation of DSM used in fractional PLL (Read 11745 times)
lwzunique
Jan 18th, 2017, 2:54am
I use the dsm model provided by cadence pllMMLib:SDM_MASH_3rd_111_macro. and run trans analysis,and then do psd to the output of the decimal output, range is -3 to 4. but the spectral is wrong?
the psd setting is as in the picture.
the frequency of the input clk is 16.384Mhz.
lwzunique
Re: power spectral density simulation of DSM used in fractional PLL
Reply #1 - Jan 18th, 2017, 3:02am
cheap_salary
Reply #2 - Jan 18th, 2017, 3:51am
lwzunique wrote on Jan 18th, 2017, 2:54am:
Plot it x-axis as log scale.
And apply Hanning window.
Did you confirm validity of output sequence of "pllMMLib/SDM_MASH_3rd_111_macro" ?
I don't use "pllMMLib/SDM_MASH_3rd_111_macro".
See http://www.designers-guide.org/Forum/YaBB.pl?num=1361756819/3#3
lwzunique
Reply #3 - Jan 18th, 2017, 5:55pm
cheap_salary wrote on Jan 18th, 2017, 3:51am:
the output sequence of "pllMMLib/SDM_MASH_3rd_111_macro"  is -3 to 4, and its average value is the input fractional data, I think it is valid.
and when do psd to the decimal output, I also made it simple at every delatN number(I mean each decimal number in the psd time range.) hanning widow is also adopted. but the result, the shape of the psd curve not like you showed in this topic:http://www.designers-guide.org/Forum/YaBB.pl?num=1361756819/3#3, and the magnitude of the psd is also not in accordance with that in:http://literature.cdn.keysight.com/litweb/pdf/5989-9471EN.pdf, and have great difference with the result I got with simulink.
in cadence spectre simulation, my input clock's T is 50ns, so begin at 75ns and end at 3276.875u, there will be 65536 simples. I show it in the picture.
my question is:
1.why my curve shape is not like yours?
2.why the magnitude of the curves are so different from each other?
3.when do PSD, we should also apply dB10 to PSD function, right?
4.why should we choose hanning window, and if the window size surpass 1024, the psd result will be wrong, why?
lwzunique
Reply #4 - Jan 18th, 2017, 6:41pm
I changed the clock to 1MHz and BIT to 20 as you did in:http://www.designers-guide.org/Forum/YaBB.pl?num=1361756819/3#3
but in my simulation the order is mash111 not mash1111. the result is more like.
another question: let make it question 5: what do the smooth factors mean, it doesn't work when I changed the value?
cheap_salary
Reply #5 - Jan 18th, 2017, 8:11pm
lwzunique wrote on Jan 18th, 2017, 6:41pm:
Always you don't see anything carefully.
My examples are MASH-11. MASH-111 and MASH-1111.
Definition of FFT is different between MATLAB and Cadence ADE.
lwzunique
Reply #6 - Jan 18th, 2017, 8:49pm
thank you,@cheap_salary, in the:http://www.designers-guide.org/Forum/YaBB.pl?num=1361756819/3#3,how to get the smoothed-spectrum?
cheap_salary
Reply #7 - Jan 18th, 2017, 8:59pm
See delta-sigma toolbox of MATLAB.
I ported "circ_smooth()" to Cadence ADE as Skill function.
https://jp.mathworks.com/matlabcentral/fileexchange/19-delta-sigma-toolbox/conte...
« Last Edit: Jan 19th, 2017, 4:28am by cheap_salary »
cheap_salary
Reply #8 - Jan 19th, 2017, 4:22am
lwzunique wrote on Jan 18th, 2017, 5:55pm:
No. It is no more than range of output codes.
You have not confirmed output sequences at all.
Maybe, output sequences are correct.
Definition of fft() is different between Keysight ADS PostProcessing and MathWorks MATLAB.
Study fft().
Definition of fft() is same between Keysight ADS PostProcessing and Cadence ADE PostProcessing.
http://www.designers-guide.org/Forum/Attachments/QQ20170119103715.jpg seems reasonable.
This PSD is for delta_N, that is, frequency, so slope is +60dB/dec=2*order*20dB/dec.
PSD for phase is +40dB/dec=2*(order-1)*20dB/dec.
See http://www.designers-guide.org/Forum/YaBB.pl?num=1444923186/6#6
Simply your setting for psd() is not appropriate.
Right.
See Appendix-A of the followings.
https://www.amazon.com/Understanding-Delta-Sigma-Converters-Richard-Schreier/dp/...
Study psd().
See http://www.designers-guide.org/Forum/YaBB.pl?num=1405235104
I can not understand what you want to mean at all.
lwzunique
Reply #9 - Jan 19th, 2017, 4:21pm
when doing psd in cadence spectre calculator, there is an option:smoothing factor.
