May 1st, 2024, 4:38am
MIM Capacitor Tutorials & Errors (Read 4222 times)
SenthilRajan
Jan 24th, 2017, 8:37pm
Dear all,
            i doing layout for OTA with feedback,
in that i am using 15pF MIM capacitoance using UMC180nm Technology
file.i generated 15pF MIM capacitance using 10x10 matrix of 150fF MIM
capacitance(all are connected parallel) to improve matching to obtain
gain of  100.when i run the post-layout simulation during lower
frequencies the AC analysis output waveform is not same as pre-layout
simulation results.need help to resolve this error.
ULPAnalog
Re: MIM Capacitor Tutorials & Errors
Reply #1 - Jan 25th, 2017, 1:19am
Is it a capacitive coupled amplifier? If so, is this 15pF input capacitance or the feedback capacitance?
Extracted netlist generally does not have mismatch enabled and needs to be explicitly added (in most cases). Therefore the issue might not be related to mismatch but rather due to parasitics. Moreover good matching practices include laying both feedback capacitance and input capacitance in a common centroid fashion and adding dummies to create similar looking environment for all caps.
Please post the schematics, pre and post layout sims, including the extraction type (C+CC or R+C+CC) to better understand the problem.
SenthilRajan
Reply #2 - Jan 25th, 2017, 9:19pm
Yes the circuit is capacitive coupled instrumentation amplier.15pF capacitance is input capacitance and 150fF capacitance is feedback capacitance,i did RC extration.if i have to include dummy capacitance,what value i have to include in capacitance layout.if possible where i have to refere for tutorials?
ULPAnalog
Reply #3 - Jan 26th, 2017, 1:38am
There are several documents available on the web detailing good layout practices for matching passives. One of those is http://www.eecg.toronto.edu/~johns/ece1371/slides/ECE1371_Mismatch-2.pdf
Since you have a differential amplifier at hand, you need to match sensing electrode and reference electrode paths to avoid cm-dm conversion.
Use of mos devices as pseudo resistors, while is a common practice in biopotential amplifiers, their modelling is rather poor under such operating conditions.
SenthilRajan
Reply #4 - Jan 27th, 2017, 5:18am
Thank You the link material  helped lot..i got same output for pre-layout and post-layout..thank you once again
ULPAnalog
Reply #5 - Jan 28th, 2017, 11:01am
Good to know that you got it working. If you could post the problem and its solution, it would help others who might run into similar issue in future.
Best regards
