Nov 9th, 2025, 10:49am
Simulating noise from slow clocked reset (Read 3765 times)
simsim
Feb 07th, 2017, 1:22pm
I have an amplifier whose output is sampled at 30 kHz. However I apply a reset signal to the amplifier at slower frequency. The reset frequency is configurable, but 100 Hz is a good refresh rate. What would be a good simulation to capture the slow reset noise.
For example, running a pss analysis with beat frequency 100 Hz, and pnoise with frequency span 15 kHz?
Mohit
