cheap_salary
We can use following special codes in Smith Chart Markers of Cadence ViVA.
%C--Displays the real and imaginary cartesian values
%Z--Displays the impedance values, such as resistance and reactance
%A--Displays the admittance values, such as conductance and susceptance
%R--Displays the reflection coefficients, such as mag and angle
Units are showed as "Ohm" even if we use %C, %A or %R for "impedance mode".
On the other hand, units are showed as "S" even if we use %C, %Z or %R for "admittance mode"
Is this known issue ?
