May 4th, 2024, 1:51am
Units showed by Smith Chart Markers of Cadence ViVA (Read 569 times)
cheap_salary
Feb 24th, 2017, 4:39am
We can use following special codes in Smith Chart Markers of Cadence ViVA.
%C--Displays the real and imaginary cartesian values
%Z--Displays the impedance values, such as resistance and reactance
%A--Displays the admittance values, such as conductance and susceptance
%R--Displays the reflection coefficients, such as mag and angle
Units are showed as "Ohm" even if we use %C, %A or %R for "impedance mode".
On the other hand, units are showed as "S" even if we use %C, %Z or %R for "admittance mode"
Is this known issue ?
Re: Units showed by Smith Chart Markers of Cadence ViVA
Reply #1 - Mar 2nd, 2017, 3:51am
I couldn't find any CCR requesting that this is changed, so I don't think it's been reported before. You should report this to Cadence via http://support.cadence.com
