Jul 15th, 2024, 11:28pm
Limits of Phase noise L(f) = Sphi(f)/2 (Read 2686 times)
deba
Mar 23rd, 2017, 2:43am
The phase noise L(f) is defined as
L(f) = Power in 1 Hz at offset (Fo+f)/Power of fundamental(Fo). This equation is in Voltage domain. If one consider small angle approximation for phase than, L(f) = Sphi(f)/2, where Sphi(f) is the single sided PSD of phase. Under what conditions, L(f) is not equal to Sphi(f)/2. In other words, if a voltage spectrum of clock is given, in which region does one can apply L(f)=Sphi(f)/2?
Re: Limits of Phase noise L(f) = Sphi(f)/2
Reply #1 - Mar 23rd, 2017, 6:48pm
This is discussed in Introduction to RF Simulation and its Application, in the section on oscillator (3.2). Basically, the approximation breaks down at very low frequencies (at frequencies less than the linewidth if flicker noise is neglected). Generally these frequencies are so low as to be uninteresting to designers.
deba
Reply #2 - Mar 24th, 2017, 4:11am
Hi Ken,
Thanks for the reference.
