subtr
![](https://designers-guide.org/forum/avatars/superman.gif)
Analog Enthusiast
India
I would like to represent a non linear DAC using a verilogA block. Fundamentally, I would like to read a file where I have 8 bit code as first column and get the corresponding real number from column two and pass it to a real variable in my code. Since it's discrete look up table, interpolation is not required. Could anyone give a sample example with the function which is capable of doing this?
