Jul 21st, 2024, 12:25pm
Modelling DAC non linearity using look up table (Read 2972 times)
subtr
Analog Enthusiast
India
Mar 29th, 2017, 10:37pm
I would like to represent a non linear DAC using a verilogA block. Fundamentally, I would like to read a file where I have 8 bit code as first column and get the corresponding real number from column two and pass it to a real variable in my code. Since it's discrete look up table, interpolation is not required. Could anyone give a sample example with the function which is capable of doing this?
Subtr
Re: Modelling DAC non linearity using look up table
Reply #1 - Mar 30th, 2017, 12:36am
Have you looked at the $table_model function? That should do what you want...
ULPAnalog
Reply #2 - Mar 31st, 2017, 9:07am
Hi Andrew
Thanks for the information on $table_model. I was wondering if this was a more recent addition to the standard as I do not see it mentioned in Ken's book on Verilog AMS.
Best regards
Reply #3 - Apr 5th, 2017, 5:01am
Indeed, I see that Ken's book references version 2.1 of the Verilog-AMS language reference manual. I got involved with VAMS after 2.2 was released, which has $table_model. Now we're on 2.4; Ken's book could do with an update!
Reply #4 - Apr 6th, 2017, 1:37pm
Although as version 2.2 of the LRM came out in November 2004 (i.e. over 12 years ago), it's hardly a recent addition to the language! Unfortunately it missed Ken and Olaf's book by a few months...
