Apr 27th, 2024, 11:47am
Veriloga module for current mode passive mixer (Read 2439 times)
chethan_RFIC
chennai
Apr 28th, 2017, 4:21am
hi all,
I am tying to design Veriloga current mode passive mixer. but i do have some doubts in this. i need to get a in put as current and multiply it with LO voltage. but the gain which is given in voltage quantity.
when i am getting output equation with non linearity.
a = I(in)*V(LO)
I(out) = alpha1*a - alpha2*a*a - alpha3 * a*a*a
here alpha1, alpha2, alpha3 are calculated with voltage gain, can i multiply current 'a' with alpha in current output.
please help me
thanks
chethan
Re: Veriloga module for current mode passive mixer
Reply #1 - May 1st, 2017, 5:56am
chethan_RFIC wrote on Apr 28th, 2017, 4:21am:
Do you mean, is it legal (in the Verilog-A language) to do the multiplication? Yes.
If you are asking if your equation matches the way the voltage gain quantity was provided, I don't think we have enough information on how that gain was provided/measured.
chethan_RFIC
chennai
Reply #2 - May 2nd, 2017, 2:46am
Thanks for reply. i know that multiplication works in veriloga language. But need any example are tutorials on current mode passive mixers and its linearity Definition in  current mode.
