Jul 15th, 2024, 9:24pm
POLY1 must be covered by N+ or P+ implant layer @Umc40lp using Calibre (Read 941 times)
Ramakrishna RSSM
May 07th, 2017, 2:44am
Hi All,
I'm working on Cadence IC616 with UMC40LP technology & using Calibre for DRC. I've encountered following DRC error.
Exclude AA_CELL_MARK, HR and MR layers
I've turned ON the following switches Since it's a block level Design.
DRC UNSELECT CHECK L2_DENSITY // AL_RDL density checking
DRC UNSELECT CHECK POLY_DENSITY // PO1 density checking
DRC UNSELECT CHECK DIFF_DENSITY // DIFFUSION density checking
Follow the attachment for more details.....
Please do let me know how to handle this DRC...
Thanks in advance...
ajithkv
Re: POLY1 must be covered by N+ or P+ implant layer @Umc40lp using Calibre
Reply #1 - Jan 26th, 2024, 8:16am
The DRC violation is for the poly segment connecting PMOS and NMOS gates. You can add/ extend P+ and N+ implant layers between the MOS devices, such that they are touching. This will cover all poly layers by either P+ or N+ implant.
