Aug 14th, 2024, 5:03pm
simple question about antenna (Read 2248 times)
si9dan2011
May 15th, 2017, 1:38am
Hi all, I would like to know,  if a good performance Tx antenna is also a good Rx antenna.  Assumed all Tx and Rx conditions are same.
Thanks.
cheap_salary
Re: simple question about antenna
Reply #1 - May 15th, 2017, 3:59am
si9dan2011 wrote on May 15th, 2017, 1:38am:
Yes.
Cosider "Reciprocity"
si9dan2011
Reply #2 - May 15th, 2017, 8:56pm
Thank you for your reply Cheap.
So let say, if I tuned my transceiver antenna to which I found the field strength during the transmission is maximum, can I assume I will receive a good signal also?
cheap_salary
Reply #3 - May 16th, 2017, 6:27am
Do you have very basic knowledge about linear circuit ?
si9dan2011 wrote on May 15th, 2017, 8:56pm:
Yes.
Surely understand "Reciprocity".
