Apr 29th, 2024, 12:39am
Monte-Carlo Simulations in UMC180...? (Read 3717 times)
Ramakrishna RSSM
May 20th, 2017, 3:35am
How to rum Monte-Carlo Simulations in Cadence Virtuoso Analog Design Environment...? I'm using UMC180 Technology on IC616. The model files are been loaded to ADE automatically because of *.il file at schmatic level. I'm able to locate Monte Carlo model fles @ /Models/Spectre/Monte_Carlo. Since in my design I'm using only NMOS & PMOS, I've to use only
mm180_reg18_v124_mc.lib.scs
mm180_reg18_v124_mc.mdl.scs
mm180_reg18_v124_mc_corner.lib.scs
mm180_reg18_v124_mc_statistical_m.mdl.scs
mm180_reg18_v124_mc_statistical_p.mdl.scs.
Kindly let me know how to run MC @ ADE-XL..?
Am i need to modify anythind in the above said files since it saying..
ERROR (ADEXL-5052): Monte Carlo run stopped because no statistical data generated for the test
Follow the attachments for my concern......
Thanks in advance.......
Re: Monte-Carlo Simulations in UMC180...?
Reply #1 - May 22nd, 2017, 8:11am
"Nominal simulation may have failed."
Can you run the nominal simulation?
Can you run a single MC trial and view the simulator log file?
Ramakrishna RSSM
Reply #2 - May 22nd, 2017, 10:51pm
Thanks a lot for your reply Geoffrey_Coram.
The issue has been resolved....
Add "* parameters sigma = 3* " in
MM180_REG18_V124_MC_STATISTICAL_P.mdl.scs
file.
A Kumar R
India
Reply #3 - May 24th, 2017, 5:38am
And, what does that mean?
and, why only add to PMOS.scs file?
Ramakrishna RSSM
Reply #4 - May 24th, 2017, 7:34am
Thanks a lot for you Question AnilReddy.
To the best of my knowledge...
Where
p---> Process
m--->mismatch
Contributions....
