May 6th, 2024, 1:47pm
How to reduce the overshoot due to a RCL step response? (Read 1124 times)
Jacki
Jun 01st, 2017, 3:08am
   I am facing a problem of overshoot ringing. I use 2.5 V IO transistors as the output stage, because of the parasitic inductors (estimated as 1 nH) at both VDD and VSS, the output signal starts overshoot and ringing a bit. This overshoot voltage (peak value is 3.8 V) is over the breakdowm voltage, I am afraid it will damage the transistor or reduce the life time. Does anybody have the experience on solving this overshoot problem?
   I know the overshoot in the step response of the RCL is fundamental problem (as shown here http://www.cvel.clemson.edu/emc/calculators/RLC_Calculator/index.html), I try to reduce it, or else I have to change the transistors to 3.3 V IO transistors (bad option).
   Any comments are highly appreciated.
   Thank you.
deba
Re: How to reduce the overshoot due to a RCL step response?
Reply #1 - Jun 1st, 2017, 3:19am
You can size the damping resistor such that there is no overshoot. Q≤0.5 should do the job.
Jacki
Reply #2 - Jun 1st, 2017, 4:04am
deba wrote on Jun 1st, 2017, 3:19am:
Thank you for your reply. I forget to mention that I cannot add the resistor to lower the Q, it also lowers the efficiency.
Jacki
Reply #3 - Jun 1st, 2017, 4:14am
Also on-chip decoupling capacitor is not a choice because I don't have enough space for it, and off-chip decoupling capacitor between VDD and VSS doesn't help.
Reply #4 - Jun 1st, 2017, 10:57am
You might try looking through Power Supply Noise Reduction and see if you find anything that helps.
Jacki
Reply #5 - Jun 2nd, 2017, 2:40am
Thank you very much Ken, I will try to see if the mutual inductance can help, also with the careful routing in the layout.
