Jul 21st, 2024, 1:29am
CMRR effects of error amp in LDO (Read 1918 times)
leejooseong222
Jun 10th, 2017, 10:32pm
hi
i wonder the effects of low CMRR error amp in LDO
low CMRR can generate offset, but i think some offset in LDO doesnt make that large issue.
and large W/L can lower the offset
what do you guys think?
+ does low CMRR make  common mode positive feedback? if that, how can i simulate that stb??
Horror Vacui
Dresden, Germany
Re: CMRR effects of error amp in LDO
Reply #1 - Jun 11th, 2017, 12:58am
I argue your statement that offset is not a problem in an LDO, since it stands for low-drop-out. For say 150mV dropout even 20mV is a lot. If you have enough dropout to waste through your pass device, then the right term would be voltage regulator.
Large W/L might reduce your input offset, but not your output one. You should isolate your signals from the supply rails.
Otherwise since your common mode range is fixed by a low resistance voltage reference - I am just guessing here - and it will not be tuned in a wide range, CMRR has little sense to me. Of course I also assume that there is no ground reference between your feedback divider and your reference.
leejooseong222
Reply #2 - Jun 11th, 2017, 4:20am
thank you for reply
actually i made voltage regulator for low supply application (under 0.5v)
so i employed 4 TR error amp (pseudo amplifier, 5 TR basic single ended amp without tail current)
all TR operates in sub treshold so WL sizes are very big ( tens um range)
the error amp has very poor CMRR, but when i did monte carlo simulation, the maximum offset was under 5 mV (offset = reference voltage - output volatge)
loop performance : DC gain is higher than 20 db, PM is larger than 50 deg.
i think these are enough performances for my application, but measured results were not good.
now i debug, the poor CMRR would make the problem... the simulation could not catch the common mode issues(common mode positive feedback...etc..)
what eles can i think or simulate?....
