Aug 14th, 2024, 10:55am
Validation of $write() for encrypted Verilog-A modules in Cadence Tool (Read 4272 times)
cheap_salary
Jun 19th, 2017, 8:40am
I can encrypt the "mymodule.va" file in both Cadence Tool and Synopsys HSPICE.
For Cadence Tool
unix> ncprotect -extension vap -language vlog -autoprotect mymodule.va
For Synopsys HSPICE
unix> metaencrypt -i mymodule.va -o mymodule.vap -t randkey
My Verilog-A module includes $write().
analog begin
   @(initial_step) begin
	$write("\n");
	case(mode)
	   0 : $write("%M: Constant Current Mode(Inom=%.2fuA)\n", Inom/1u);
	   1 : $write("%M: Constant Resistance Mode(Vnom=%gVolts, Inom=%.2fuA, Rnom=%.2fkohm)\n",
		 Vnom, Inom/1u, Rnom/1k);
	   2 : $write("%M: Clip Current Mode(Imin=%.2fuA, Imax=%.2fuA, Vth=%gVolts, Vknee=%gVolts)\n",
		 Imin/1u, Imax/1u, Vth, Vknee);
In HSPICE, $write() is valid even for encrypted Verilog-A modules.
However $write() is not valid for encrypted Verilog-A modules in Cadence Tools.
How can I make $write() valid in Cadence Tool ?
Re: Validation of $write() for encrypted Verilog-A modules in Cadence Tool
Reply #1 - Jul 25th, 2017, 9:38am
The only way is to use the //pragma constructs in the file to turn on and off encryption so that the $write statements are not encrypted.
Maybe  you should file an enhancement CCR to allow ncprotect to have an option to allow $write statements to work when inside encrypted code. It would have to be an encryption-time decision, I think.
I've not found any other requests for this - but it seems a reasonable request to me that you should be allowed to decide whether they are enabled or not.
cheap_salary
Reply #2 - Jul 28th, 2017, 12:45am
Thank for answering.
Warning from spectre during AHDL read-in.
    WARNING (VACOMP-2343): Cannot display/strobe/write information or call $system from a protected analog block.
Andrew Beckett wrote on Jul 25th, 2017, 9:38am:
Could you teach me what I should do in detail ?
Do you mean like following ?
`pragma protect begin
module A; //This module will be encrypted
`pragma protect end
module B; //This module will not be encrypted
Reply #3 - Aug 2nd, 2017, 9:14pm
Here's an example I used:
`include "disciplines.vams"
//pragma protect
//pragma protect begin
module desguide2 (mon,vss);
inout mon,vss;
electrical mon,vss;
parameter real Inom=2u;
parameter real Vnom=2.0;
parameter real Rnom=1k;
parameter real Vknee=3.0;
parameter real Vth=0.7;
parameter real Imin=0.1u;
parameter real Imax=10u;
parameter integer mode=1;
analog begin
//pragma protect end
	$write("\n");
	case(mode)
	endcase
//pragma protect
