Mar 28th, 2023, 4:35am
Issue of unrecognized system task or function: $cdn_ahb_access (Read 753 times)
TDG_40
Nov 28th, 2017, 6:23am
I'm trying to verify the simple AHB block by using VIPCAT, so I made simple test.v as the below
`timescale 1ps/1ps
module test2(
   HCLK,
   HRESET,
   HADDR,
   HTRANS,
  HLOCK,
   HGRANT
   parameter interface_soma = "test2.soma";
   parameter init_file   = "";
   parameter sim_control = "";
   input HCLK;
   input HRESET;
   output [31:0] HADDR;
     assign HBUSREQ = den_HBUSREQ;
   output HLOCK;
     reg den_HLOCK;
     assign HLOCK = den_HLOCK;
   input HGRANT;
initial
   $cdn_ahb_access(HCLK,HRESET,den_HADDR,den_HTRANS,den_HWRITE,den_HSIZE,den_HBURS
T,den_HPROT,den_HWDATA,HRDATA,HREADY,HRESP,den_HBUSREQ,den_HLOCK,HGRANT);
And I want to use the VIPCAT to generate a BFM file for the AHB interfacing test.
But I'm stuck in the below process. How do I resolve this problem?
When I execute with the below command
$ncverilog +access+wrc test2.v
then I've got the below errors    $cdn_ahb_access(HCLK,HRESET,den_HADDR,den_HTRANS,den_HWRITE,den_HSIZE,den_HBURS
ncelab: *W,MISSYST (./test1.v,70|18): Unrecognized system task or function: $cdn_ahb_access (did not match built-in or user-defined names) [2.7.4(IEEE Std 1364-2001)]
Could you please help me how can I resolve this problem?.
I've attached with file (.v and executing file)
Would you help me how do I get the correct executing file?
Re: Issue of unrecognized system task or function: $cdn_ahb_access
Reply #1 - Dec 21st, 2017, 7:21am
Not really my field, but some records of this suggest that it's due to not having been set up or not including the VIP PLI on the command line.
I suggest you try doing (set the path to your installation with setenv if csh, or export if using bash/ksh):
setenv CDN_VIP_ROOT /path/to/VIPCAT_release
$CDN_VIP_ROOT/tools/denali/example/cdn_ahb/svExamples/simpleExample/example_setu
p_ncsim.csh
Do this in an empty directory and then inspect the various files in the directory.
If this doesn't help, best to go to support.cadence.com and ask for help...
