It works for me (using XCELIUM 18.10). I suspect that your problem is that you're only seeing the final value of i at each time - that's because the for loop increments i at the same time, with no delay - and $monitor outputs only the final value. From the IEEE 1364-2001 LRM (section 17.1): Quote:When a $monitor task is invoked with one or more arguments, the simulator sets up a mechanism whereby each time a variable or an expression in the argument list changes value—with the exception of the $time, $stime or $realtime system functions—the entire argument list is displayed at the end of the time step as if reported by the $display task. If two or more arguments change value at the same time, only one display is produced that shows the new values. If (for example) I add a delay: Code:#1 if((stag[i]^ptag[i]))
and then also change the final #10 to a #20 to allow sufficient time for the loop to complete, I then get: 0 stag=xxxx,ptag=xxxx,tag_equal=x, i=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx 10 stag=000a,ptag=000b,tag_equal=x, i=00000000000000000000000000001111 11 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000001110 12 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000001101 13 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000001100 14 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000001011 15 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000001010 16 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000001001 17 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000001000 18 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000000111 19 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000000110 20 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000000101 21 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000000100 22 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000000011 23 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000000010 24 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000000001 25 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000000000 26 stag=000a,ptag=000b,tag_equal=0, i=11111111111111111111111111111111 30 stag=000b,ptag=000b,tag_equal=0, i=00000000000000000000000000001111 31 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000001110 32 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000001101 33 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000001100 34 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000001011 35 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000001010 36 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000001001 37 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000001000 38 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000000111 39 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000000110 40 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000000101 41 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000000100 42 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000000011 43 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000000010 44 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000000001 45 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000000000 46 stag=000b,ptag=000b,tag_equal=1, i=11111111111111111111111111111111Regards, Andrew.
