Jul 2nd, 2025, 8:55pm
how to print integer in the verilog module (Read 1850 times)
liletian
MD
Aug 08th, 2018, 10:34am
Hi All
I write the following module comparator, In the testbench, I would like to monitor integer i, when I try to print out the interger using the following statement, it does not work. Is there a way to keep track of the interger in the testbench?
Thank you very much,
module comparator(stag,ptag,tag_equal);
parameter n=16;
input [n-1:0] stag,ptag;
output tag_equal;
reg tag_equal;
integer i;
// initial begin
// tag_equal<=1'b1;
// end
always @(stag or ptag)
for(i=n-1;i>=0;i=i-1)
begin: sweep
if((stag[i]^ptag[i]))
begin
tag_equal<=1'b0;
// break;
// disable sweep;
else tag_equal<=1'b1;
module test_comparator();
parameter n=16;
reg [n-1:0] A,B;
wire tag_equal;
comparator #(n) com(.stag(A),.ptag(B),.tag_equal(tag_equal));
initial begin
$monitor($stime, " stag=%h,ptag=%h,tag_equal=%b, i=%b", A,B,tag_equal,com.i);
#10;
A=16'h000A;
B=16'h000B;
#10;
A=16'h000B;
B=16'h000B;
end // initial begin
Re: how to print integer in the verilog module
Reply #1 - Aug 9th, 2018, 4:26am
It works for me (using XCELIUM 18.10). I suspect that your problem is that you're only seeing the final value of i at each time - that's because the for loop increments i at the same time, with no delay - and $monitor outputs only the final value. From the IEEE 1364-2001 LRM (section 17.1):
Quote:
When a $monitor task is invoked with one or more arguments, the simulator sets up a mechanism whereby each time a variable or an expression in the argument list changes value—with the exception of the $time, $stime or $realtime system functions—the entire argument list is displayed at the end of the time step as if reported by the $display task. If two or more arguments change value at the same time, only one display is produced that shows the new values.
If (for example) I add a delay:
#1 if((stag[i]^ptag[i]))
and then also change the final #10 to a #20 to allow sufficient time for the loop to complete, I then get:
        0 stag=xxxx,ptag=xxxx,tag_equal=x, i=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
       10 stag=000a,ptag=000b,tag_equal=x, i=00000000000000000000000000001111
       11 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000001110
       12 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000001101
       13 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000001100
       14 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000001011
       15 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000001010
       16 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000001001
       17 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000001000
       18 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000000111
       19 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000000110
       20 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000000101
       21 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000000100
       22 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000000011
       23 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000000010
       24 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000000001
       25 stag=000a,ptag=000b,tag_equal=1, i=00000000000000000000000000000000
       26 stag=000a,ptag=000b,tag_equal=0, i=11111111111111111111111111111111
       30 stag=000b,ptag=000b,tag_equal=0, i=00000000000000000000000000001111
       31 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000001110
       32 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000001101
       33 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000001100
       34 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000001011
       35 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000001010
       36 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000001001
       37 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000001000
       38 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000000111
       39 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000000110
       40 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000000101
       41 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000000100
       42 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000000011
       43 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000000010
       44 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000000001
       45 stag=000b,ptag=000b,tag_equal=1, i=00000000000000000000000000000000
       46 stag=000b,ptag=000b,tag_equal=1, i=11111111111111111111111111111111
