Jul 2nd, 2025, 8:54pm
Not effective envSetVal() for Layout in Cadence Virtuoso (Read 2922 times)
cheap_salary
Jul 28th, 2017, 1:09am
I've used "envSetVal()" in ".cdsinit" for setting my custom enviroments like following.
envSetVal("layout" "startLevel" 'int 0)
envSetVal("layout" "stopLevel" 'int 32)
;[Set Working Grid]
envSetVal("layout" "xSnapSpacing" 'float 0.005) ; [um]
envSetVal("layout" "ySnapSpacing" 'float 0.005) ; [um]
;[Set Display Minor Grid]
envSetVal("layout" "gridSpacing" 'float 0.1) ; Minor Spacing [um]
;[Set Display MajorGrid]
envSetVal("layout" "gridMultiple" 'int 5) ; (=Major_Spacing/Minor_Spacing)
envSetVal("layout" "dynamicHilightOn" 'boolean nil)
But these can not be effective recently.
What causes prevent to change environment ?
Re: Not effective envSetVal() for Layout in Cadence Virtuoso
Reply #1 - Aug 2nd, 2017, 9:23pm
Not sure this is in the right forum (probably should have been in Entry Tools) - but never mind.
My guess is that you have saved the environment settings to your design or library. For example at the bottom of the Options->Display form there are choices to save the settings to CellView, Library, Tech Library or cdsenv.
If this has been done, then these win over any cdsenv settings. The highest priority is the cellView, then library, then tech library, then the cdsenv settings.
You can tell if this has been done by looking at the cellView properties (File->Properties in the layout editor), or in the library manager over the library name (or tech library name) Right Mouse->Properties and if there's a property called "viewProps" with a button EXPAND, then you can expand and see maskLayout (and EXPAND again) and then see the individual settings.
The Options->Display form has the ability to Delete from the location it's saved to - so that can be a way of removing these library or cellView-specific settings if that hadn't been intended.
cheap_salary
Reply #2 - Aug 7th, 2017, 7:22am
Andrew Beckett wrote on Aug 2nd, 2017, 9:23pm:
Thanks for response.
I delete cellview property.
Now "envSetVal("layout",....)" in ".cdsinit" are effective.
BTW, I can set grid setting for layout at startup on Virtuoso by ".cdsinit".
However I can not change grid setting dynamically during session by "envSetVal("layout",....)".
How can I change grid setting dynamically during session by skill-language ?
Reply #3 - Aug 7th, 2017, 10:21am
Assuming you mean the gridSpacing or gridMultiple then:
hiGetCurrentWindow()~>gridSpacing=0.2
hiGetCurrentWindow()~>gridMultiple=10
If you were talking about the snap spacing, then it would be xSnapSpacing or ySnapSpacing.
Put another way, you set attributes on the window to affect the current layout window; the cdsenv vars (or cellView/lib/tech lib properties) only affect new windows.
