Apr 27th, 2024, 11:41am
Question on mutual capacitance change on other neighboring conductors (Read 1371 times)
neoflash
Mixed-Signal
Designer
Jul 30th, 2017, 10:49am
I am looking for articles or textbooks that can explain the impact of 3rd conductor on mutual capacitance on two conductors.
For example, for many capacitance sensing scheme, the mutual C between sensor and object will change linearly with distance if no other conductors nearby. However, if there is other conductor close to sensor, the mutual C drops much faster with distance.
If any material helps understand this better, I would really appreciate it.
Maks
San Jose
Re: Question on mutual capacitance change on other neighboring conductors
Reply #1 - Jul 31st, 2017, 9:36am
Capacitance change (inversely) linearly with distance only for a parallel-plate capacitor, or - for any capacitor if the change (of the distance) is small.
In general, introduction of a third body (a conductor with fixed voltage -
i.e. not floating) close to the "plates" of a capacitor will reduce the capacitance between the plates.
I never heard of a statement that the rate of capacitance change is faster in the presence of a third body.
I don't think you will find a detailed theoretical discussion of this thing in the literature. People do simulate capacitance, but it is not considered a cutting edge research, in general. And if it is a cutting edge research for some companies (like capacitive touch sensors) - they would keep this as a trade secret, not publishing the results.
Max
