Sep 25th, 2026, 1:08pm
Fully Differential Opamp MacroModel in Cadence (Read 1624 times)
repah
Aug 26th, 2017, 4:21pm
I am trying to design a fully differential opamp (infinite gain, infinite bandwidth) with Cadence to simulate a Discrete Time Sigma Delta Modulator at the system level.
What is best to use ?  A Verilog model ? or Controlled sources - VCCS etc.
Does anyone have any examples of controlled source model macromodels for a fully differential opamp ?
Thank you.
davidshw
China
Re: Fully Differential Opamp MacroModel in Cadence
Reply #1 - Aug 28th, 2017, 5:25pm
here is a verilog-a model for you reference.
// VerilogA of Two-stage Differential OTA
`include "constants.vams"
`include "disciplines.vams"
module opamp_diff_2stage(VOP, VOM, VP, VM, VCM, VDD,VSS);
output VOP;
electrical VOP;
output VOM;
electrical VOM;
input VM;
electrical VM;
input VP;
electrical VP;
input VCM;		//output common-mode voltage
electrical VCM;
input VDD,VSS;
electrical VDD,VSS;
parameter real gain = 1e6 ;		//dc gain
parameter real f0 = 1e7 ;		//0dB BW of 1st-pole system with cload;
parameter real f2 = 10e7 ;		//non-domainant pole of two-stage ota
parameter real cload = 1p ;		//OTA output loading capacitance;
parameter real ro2 = 100e3 ;		//2nd stage ota output res
parameter real cicm = 10f ;		//1st stage cm cap
parameter real vod_diff = 0.2 ;		//input stage MOS over-drive voltage
parameter real vsoft= 0.1 ;		//output soft limit voltage (vdsat)
	real gm1,gm2,ro1,vin_max,iin_max,idiff,gain1,gain2,slew_rate, satp,satn;
	real rout1, gout1 ;
	real rout2, gout2;
	real co1,co2,cc, tmp;
	electrical VMID, VO1P, VO1M, VBUFP, VBUFM, VOCM;
	real gain_cmfb, gm_cmfb ;
	analog begin
      		@ ( initial_step or initial_step("dc") ) begin
			cc=1p;		// compensation cap
			co1 = 1f ;	//1st stage output cap
			co2 = 1f ;	//2nd stage output cap
			gm1=2*`M_PI*f0*cc;
			gm2=2*`M_PI*f2*(co2+cload);
			ro1=gain/(gm1*gm2*ro2);
			gain1=gm1*ro1;
			gain2=gm2*ro2;
			iin_max=gm1*vod_diff;
			vin_max=iin_max/gm1;
			slew_rate=iin_max/cc; //=2*`M_PI*f0*vod_diff;
			gain_cmfb=10*gain;
			gm_cmfb=gain_cmfb/(ro1*gm2*ro2);
		V(VMID)<+ (V(VDD)+V(VSS))/2;
		//input cap
		I(VP)<+cicm*ddt(V(VP));
		I(VM)<+cicm*ddt(V(VM));
		// diff input stage current limit
		if(V(VP,VM)>vin_max) idiff=iin_max;
		else if(V(VP,VM)<-vin_max) idiff=-iin_max;
		else idiff=gm1*V(VP,VM);
		// output stage saturation
		if(vsoft>0) begin
			if(abs(V(VOP,VMID))<V(VDD,VMID)-vsoft) satp=1;
			else if(abs(V(VOP,VMID))>V(VDD,VMID)) satp=0;
			else begin
				tmp= (V(VDD,VMID)-abs(V(VOP,VMID)))/vsoft;
				satp= 3*pow(tmp,2)-2*pow(tmp,3);
		else 	satp = 1;
		if(vsoft>0) begin
			if(abs(V(VOM,VMID))<V(VDD,VMID)-vsoft) satn=1;
			else if(abs(V(VOM,VMID))>V(VDD,VMID)) satn=0;
			else begin
				tmp= (V(VDD,VMID)-abs(V(VOM,VMID)))/vsoft;
				satn= 3*pow(tmp,2)-2*pow(tmp,3);
		else 	satn = 1;
		gout2 = gm2 -(gm2-1/ro2)*min(satp,satn);
		rout2 = 1/gout2;
		gout1 = gm1 -(gm1-1/ro1)*min(satn,satp);
		rout1 = 1/gout1;
		// 1st-stage ota
		I(VMID,VO1P)<+ idiff/2;
		I(VMID,VO1P)<+ co1*ddt(V(VMID,VO1P));
		I(VMID,VO1P)<+ 1/rout1*V(VMID,VO1P);
		I(VMID,VO1M)<+ -idiff/2;
		I(VMID,VO1M)<+ co1*ddt(V(VMID,VO1M));
		I(VMID,VO1M)<+ 1/rout1*V(VMID,VO1M);
		// 2nd stage ota output
		I(VMID,VOP)<+ -gm2*V(VO1M,VMID);
		I(VMID,VOP)<+ co2*ddt(V(VMID,VOP)) ;
		I(VMID,VOP)<+ 1/rout2*V(VMID,VOP);
		I(VMID,VOM)<+ -gm2*V(VO1P,VMID);
		I(VMID,VOM)<+ co2*ddt(V(VMID,VOM)) ;
		I(VMID,VOM)<+ 1/rout2*V(VMID,VOM);
		// miller compensation cap with buffer
		V(VBUFP)<+V(VOP);
		I(VO1M,VBUFP)<+ cc*ddt(V(VO1M,VBUFP)) ;
		V(VBUFM)<+V(VOM);
		I(VO1P,VBUFM)<+ cc*ddt(V(VO1P,VBUFM)) ;
		// CMFB
		V(VOCM)<+(V(VOP)+V(VOM))/2;
		I(VMID,VO1P)<+ gm_cmfb*V(VOCM,VCM);
		I(VMID,VO1M)<+ gm_cmfb*V(VOCM,VCM);
Reply #2 - Sep 5th, 2017, 5:01am
Hi, davidshw -
Thanks for posting that code. I'd recommend a few tweaks:
- combine the port declarations:
output VOP, VOM;
input VP, VM, VCM, VDD, VSS;
electrical VOP, VOM, VP, VM, VCM, VDD, VSS;
- remove the "@initial_step" condition: instead of
just have
                 begin
Otherwise the simulator may think it needs to set up special storage to handle remembering those values from timepoint to timepoint.
It actually seems to me that those capacitance values ought to be parameters rather than hard-coded numbers.
