Sep 15th, 2026, 4:48pm
Transistor Width vs Noise Figure Curve (Read 2624 times)
umberabbas
Sep 20th, 2017, 9:31pm
How to extract/draw/calculate the transistor width vs Noise figure curve in Cadence Spectre?
Re: Transistor Width vs Noise Figure Curve
Reply #1 - Sep 22nd, 2017, 2:55pm
Umberabbas,
     One option would be to use the test bench in
https://community.cadence.com/cadence_blogs_8/b/rf/archive/2010/12/07/measuring-...
transistor-fmax
for Noise Figure measurements, select NF on the menu. Then run a parametric analysis sweeping the width of the device.
