Aug 14th, 2024, 11:41am
Diode spectre model (Read 2060 times)
Palz
Diode spectre model
Oct 08th, 2017, 6:53pm
I’m working on device modelling (specre model) of a pn junction diode. There are parameters gap1 and gap2 for bandgap voltage (Egalpha and Egbeta). Analytically, when egalpha and egbeta terms are changed, the bandgap voltage at a particular temperature changes.
Vg(T) = Vg0 - ((alpha * T^2)/(T+beta))
But I couldn't observe any difference in the performance of the diode nor the bandgap reference circuit when I simulated in cadence.
Could anyone please tell me why this would happen?
Re: Diode spectre model
Reply #1 - Oct 9th, 2017, 6:21am
I think gap1 and gap2 are only used when tlev=2.
Palz
Reply #2 - Oct 9th, 2017, 5:15pm
Thanks Geoffrey. I think that would be in Hspice. What about spectre models? Do you have any idea how to define levels in a spectre model?
Palz
Reply #3 - Oct 10th, 2017, 8:22am
Sorry! I'm new to device modelling. Tlev worked. Thanks!
Reply #4 - Dec 21st, 2017, 7:48am
By the way, this is all covered in the Spectre® Circuit Simulator Components and Device Models Reference manual. Take a look either via cdnshelp or looking at <SPECTREinstDir>/doc/spectremod/spectremod.pdf - there's a chapter in there in the diode equations, and it covers the different temperature level parameters too.
