Jul 2nd, 2025, 3:15am
Transistor model with variable gate capacitance (Read 1867 times)
frasheed
Oct 29th, 2017, 3:25am
I am modeling a n-type transistor. I already have DC model in verilog-a format. This DC model doesn't have capacitance in it. I am extending it to add gate capacitance. In our process technology gate capacitance is variable (please see the attached image) and I have equation for gate capacitance.
From figure, you can see that I have internal gate (ig) terminal which would be the final gate voltage for my transistor. I have a small problem, I only define current through resistor and capacitor using contributions equation:
I(g, ig) <+ V(g, ig)/RG
I(ig, d)<+ CGD*ddt(V(ig, d))
I(ig, s)<+ CGS*ddt(V(ig, s))
Now If I make an inverter logic using this extended model, if I increase the input voltage (from 0 to VDD) then Output first increase little bit over VDD and then decreases to low voltage (logic 0).
I believe the output first increases because of CGD charging and when it is charge , the output gets decreased.
Could anyone of you please tell me what is wrong with my modeling approach?.My gate capacitance realization is correct ?
P.S: My capacitances values are in nF .
« Last Edit: Oct 29th, 2017, 7:28am by frasheed »
DanielLam
Re: Transistor model with variable gate capacitance
Reply #1 - Oct 30th, 2017, 4:33pm
If you're wondering about the overshoot, that is normal. There is also undershoot. You can see this by just trying out a normal inverter. Just have a sharp rise/fall time.
Reply #2 - Oct 31st, 2017, 10:28am
frasheed wrote on Oct 29th, 2017, 3:25am:
You really should write your model in terms of gate charge. Current is dQ/dt, and for a linear capacitor, dQ/dt = C dV/dt, but for a nonlinear capacitor, this is no longer true. In particular, dC/dt is may be non-zero!
frasheed
Reply #3 - Nov 2nd, 2017, 5:06am
Hi Geoffrey_Coram,
After changing it to gate charge, I am getting convergence error for inverter logic.
Here is my complete code:
`include "constants.vams"
`include "disciplines.vams"
module fet_cap (vd, vg, vs);
	analog function real sub_threshold;
		input V0, I0, S, alpha0, lambda, vol_vgs, vol_vds;
		real V0, I0, S, alpha0, lambda, vol_vgs, vol_vds;
		begin
			sub_threshold = I0 * exp(ln(10)/S * (vol_vgs - V0)) * tanh(alpha0 * vol_vds) * (1 + lambda * vol_vds);
	endfunction
	analog function real near_threshold;
		input a, b, c, d, alpha0, lambda, vol_vgs, vol_vds;
		real a, b, c, d, alpha0, lambda, vol_vgs, vol_vds;
		begin
			near_threshold = (a * pow(vol_vgs, 3) + b * pow(vol_vgs, 2) + c * vol_vgs + d) * (tanh(alpha0 * vol_vds)) * (1 + lambda * vol_vds);
	endfunction
	analog function real gch;
		input gch0, vth_ch, gamma_ch, vol_vgs;
		real gch0, vth_ch, gamma_ch, vol_vgs;
		begin
			gch = gch0 * pow((vol_vgs - vth_ch), (1 + gamma_ch));
	endfunction
	analog function real Isat;
		input beta, vth, gamma, vol_vgs;
		real beta, vth, gamma, vol_vgs;
		begin
			Isat = beta * pow((vol_vgs - vth), (1 + gamma));
	endfunction
	analog function real alpha;
		input gch0, vth_ch, gamma_ch, beta, vth, gamma, vol_vgs;
		real gch0, vth_ch, gamma_ch, beta, vth, gamma, vol_vgs;
		begin
			alpha = gch(gch0, vth_ch, gamma_ch, vol_vgs) / Isat(beta, vth, gamma, vol_vgs);
	endfunction
	analog function real above_threshold;
		input gch0, vth_ch, gamma_ch, beta, vth, gamma, lambda, vol_vgs, vol_vds;
		real gch0, vth_ch, gamma_ch, beta, vth, gamma, lambda, vol_vgs, vol_vds;
		begin
			above_threshold = beta * pow((vol_vgs - vth), (1 + gamma)) * tanh(alpha(gch0, vth_ch, gamma_ch, beta, vth, gamma, vol_vgs) * vol_vds) * (1 + vol_vds * lambda);
	endfunction
	inout vd, vg, vs;
	electrical vd, vg, vs, ig;
	branch(vd, vs) vds;
	branch(ig, vd) vgd;
	branch(ig, vs) vgs;
	branch(vg, ig) RG;
	//Channel geometry
	parameter W=75u, L=40u;
	//subthreshold
	parameter V0 = 0.1740;
	parameter I0 = 4.1742e-08;
	parameter S = 0.0297;
	//near threshold
	parameter a = 1.2520e-04;
	parameter b = -4.8064e-05;
	parameter c = 1.0849e-05;
	parameter d = -1.0594e-06;
	parameter alpha0 = 17.1562;
	//above threshold
	parameter beta = 3.0211e-05;
	parameter vth = 0.2429;
	parameter vth_ch = 0.2430;
	parameter gamma = 0.1366;
	parameter gamma_ch = -0.8340;
	parameter gch0 =  3.8755e-05;
	parameter lambda = 0.0328;
	//Limits
	parameter VGS_epsilon1 = 0.1820;
	parameter VGS_epsilon2 = 0.3120;
	real IDS_sub, IDS_near, IDS_above;
	/////////////////PARAMETERS FOR CAPACITANCE
	parameter R = 1;
	real C, CS, CD, qd, qs;
	/////////////////////////////PARAMETERS FOR CAPACITANCES END
	analog begin
	    //Capacitance
		I(RG) <+ V(RG)/R;
		C = 4.29095598e-11 + 5.08332314e-11*tanh(V(vgs));
		CS = W*L*C;
		CD = CS;
		qs = CS*V(vgs);
		qd = CD*V(vgd);
		I(vgs) <+ ddt(qs);
		I(vgd) <+ ddt(qd);
		//Capacitance end
	    if (V(vgs) <= VGS_epsilon1) begin
			IDS_sub = sub_threshold(V0, I0, S, alpha0, lambda, V(vgs), V(vds));
			IDS_near = 0;
			IDS_above = 0;
		if (V(vgs) > VGS_epsilon1 && V(vgs) < VGS_epsilon2) begin
			IDS_sub = 0;
			IDS_near = near_threshold(a, b, c, d, alpha0, lambda, V(vgs), V(vds));
			IDS_above = 0;
	  if (V(vgs) >= VGS_epsilon2) begin
			IDS_sub = 0;
			IDS_near = 0;
			IDS_above = above_threshold(gch0, vth_ch, gamma_ch, beta, vth, gamma, lambda, V(vds), V(vds));
		I(vds) <+ W/L * (IDS_sub + IDS_near + IDS_above + 0.3e-9);
Could you please review my code ?. The DC model is from anothe developer I just added capacitance block for transient simulation.
Reply #4 - Nov 2nd, 2017, 10:06am
You have
CS = W*L*C;
qs = CS*V(vgs);
Cgs should be the partial derivative of Qs with respect to Vgs, but with what you have written,
Cgs = CS + W*L*V(vgs)*5.08332314e-11*(1-tanh^2(V(vgs)))
Reply #5 - Nov 2nd, 2017, 10:08am
and what is 0.3e-9 ?? Regardless of the node voltages -- that is, even at zero bias -- you'll get 0.3nA of current.
frasheed
Reply #6 - Nov 2nd, 2017, 10:18am
Thank you for your reply.
Geoffrey_Coram wrote on Nov 2nd, 2017, 10:06am:
You have
CS = W*L*C;
qs = CS*V(vgs);
Regarding your argument that Cgs should be partial derivative w.r.t Vgs. Could you please give me any hints or literature why it should be like this ?.
I also found a mistake in my code, CS and CD are not equal, CS and CD values are calculated from different electrodes. This is what it look like now:
vcs = V(vgs);
vcd = V(vgd);
CS = W*L*(0.4290956 + 0.50833231*tanh(vcs));
CD = W*L*(0.4290956 + 0.50833231*tanh(vcd));
qs = CS*vcs;
qd = CD*vcd;
I(vgs) <+ ddt(qs);
I(vgd) <+ ddt(qd);
Regarding 0.3e-9, The developer added it for testing purpose. We will remove it.
« Last Edit: Nov 3rd, 2017, 7:09am by frasheed »
Reply #7 - Nov 3rd, 2017, 7:19am
frasheed wrote on Nov 2nd, 2017, 10:18am:
M. A. Cirit, "The Meyer model revisited: Why is charge not conserved?", IEEE Trans. Comp.-Aided Des., vol. 8, pp. 1033-1037, Oct. 1989.
P. Yang, B. D. Epler, P. K. Chatterjee, "An investigation of the charge conversation problem for MOSFET circuit simulation", IEEE Solid-State Circuits, vol. SC-18, pp. 128-138, 1983.
D. E. Ward, R. W. Dutton, "A charge oriented model for MOS transistor capacitances", IEEE J. Solid-State Circuits, vol. SC-13, pp. 703-707, 1978.
D. E. Ward, Charge-based modeling of capacitance in MOS transistors, 1981.
