May 3rd, 2024, 10:31pm
architecture trade off on input loading of sigma-delta ADC (Read 535 times)
neoflash
Mixed-Signal
Designer
Oct 09th, 2017, 10:34am
In order to get best performance on tiny input signal, the pre-amp gain will be adjusted to properly load the trailing 20-bit sigma-delta ADC.
However, the high gain of pre-amp will introduce distortion. Give the lower speed operation, system may prefer to have a lower gain at preamp and let sigma-delta adc work harder to get the performance.
For nyquist adc, it is highly undesired to load adc very lightly, we are very motivated to load ADC near full DR.
What is the considerations for oversampling ADC in this case?
Neo
Frank_Heart
Re: architecture trade off on input loading of sigma-delta ADC
Reply #1 - Nov 17th, 2017, 10:57pm
Hi, Neo,
 I think it should be similar. We always want the pre-amp gain to be as large as possible to degrade ADC noise, referring to input. Of course, the degraded linearity should be within spec, if it is for wide band applications.
Frank
