Jan 13th, 2026, 5:18am
Avoid overwrite logfile with spectre assertion (Read 3612 times)
Gp
Oct 10th, 2017, 10:22pm
I have implemented the spectre assertion with the following example:
INV_CHECK assert sub=INV expr="V(vdd)" min=1.5 max=2.0 message="ERROR: vdd is out of range" level=error
My question is when I am run this assertion it is working fine.
But, When I am run with different test, it is overwritten. I want to make a different assertion results file with a different test.
so, Is it possible?
Re: Avoid overwrite logfile with spectre assertion
Reply #1 - Dec 21st, 2017, 7:31am
I don't understand the question. There's nothing file-related in what you've described above, so why would anything be overwritten?
