Jul 19th, 2024, 11:31pm
Integrator Leakage (finite op gain) impact on 2nd order SDM? (Read 1425 times)
neoflash
Mixed-Signal
Designer
Oct 17th, 2017, 11:28am
The impact of integrator leakage on 1st order sdm is clear. Any conclusion on its impact on 2nd order SDM from leaky 1st and 2nd integrator?
Neo
jdp
Re: Integrator Leakage (finite op gain) impact on 2nd order SDM?
Reply #1 - Oct 28th, 2017, 11:19pm
Due to leaky integrator, the low freq response of integrator gets affected (becomes flat from the expected -20dB/decade slope) - this consequently affects the NTF of the SDM, which also becomes flat instead of having 20dB/decade slope, so overall, the noise shaping gets afftected in low freq range...should be similar in case of 2nd order as well.
-- jdp
