May 3rd, 2024, 9:56pm
Trade off on using SC DAC inside CT sigma-delta ADC (Read 2422 times)
neoflash
Mixed-Signal
Designer
Nov 14th, 2017, 4:49pm
There is a technique that people use to reduce jitter sensitivity in CT sigma delta ADC.
As shown in the figure, a SC DAC used for feedback.
What is the price paid for choosing this approach?
One issue I can think of is, the instantaneous kick of SC circuit to the integrator might be a problem limiting linearity.
Any comments?
Neo
Frank_Heart
Re: Trade off on using SC DAC inside CT sigma-delta ADC
Reply #1 - Nov 17th, 2017, 12:17am
Hi, Neo,
 I would suggest you to read the book :
 Understanding Delta-Sigma Data Converters, 2nd Edition
 http://www.wiley.com/WileyCDA/WileyTitle/productCd-1119258278.html
 They have detailed discussions on SC-DAC (page 328), and explain why it is not popular.
  "In summary, while the SC feedback DAC is an intuitively appealing idea for combating clock jitter, it presents many practical implementation challenges. For one, the linearity needed of the first integrator is greatly increased due to the high peak-to-average ratio of the feedback waveform. Next, the inherent anti-aliasing feature, the hallmark of continuous-time SD modulation, is limited to about 20dB".
  BTW, if anyone have an intuitive way to understand "the inherent anti-aliasing feature, the hallmark of continuous-time SD modulation, is limited to about 20dB" in SC-DAC SDM, please share.
-Frank
neoflash
Mixed-Signal
Designer
Reply #2 - Nov 20th, 2017, 1:49pm
This is helpful. Thanks.
I am also working on understanding the intrinsic anti-aliasing nature of CT sdm now.
Frank_Heart wrote on Nov 17th, 2017, 12:17am:
Hi, Neo,
-Frank
achilles
Reply #3 - Dec 13th, 2017, 11:22pm
Hi Frank_Heart,
The same book has a different explanation on anti-aliasing feature in the appendix under the heading LPTV systems. I suggest you take a look at it. There is a very clear explanation as to why SC DACs perform badly in that regard.
