Aug 14th, 2024, 11:38am
Pages: 1 2
Virtuoso Slow Down after Large Memory exhaustion (Read 1292 times)
cheap_salary
Dec 16th, 2017, 5:46am
I use very complex and very heavy post processing with ViVa in Cadence Virtuoso.
However I always encounter "Swap Activity Warning".
Once I encounter "Swap Activity Warning", Virtuoso is very slow down and never recover normal operation speed, even if I close ViVa.
I have to restart Virtuoso to recover normal operation speed.
I think it is because Virtuoso can not release allocated memory.
Is ther any method to recover normal operation speed without restarting Virtuoso ?
Re: Virtuoso Slow Down after Large Memory exhaustion
Reply #1 - Dec 21st, 2017, 7:34am
There has been some work on this recently - but in general releasing memory back to the operating system is challenging in most applications.
Please contact Cadence Customer Support for this as then a Cadence AE can see if there's anything that can be done to help (not sure which subversion of the IC tools you're using, for example).
cheap_salary
Reply #2 - Dec 24th, 2017, 7:33am
My Subversion is:
Reply #3 - Dec 26th, 2017, 2:39am
OK - you're pretty recent (there's only one later subversion currently). I think you should talk to customer support, as I mentioned earlier - that way Cadence can get a better idea of what you're doing to see what is going on and to see if it can be improved.
cheap_salary
Reply #4 - Feb 6th, 2018, 4:32am
When I do large post processing by using Cadence Skill in IC5, I don't encounter an exhaustion of memory.
And I can complete in post processing.
However a large memory exhaustion occurs and it is never released, when I use Cadence Skill in IC6.
And I can not complete in post processing.
Here I don't use graph drawing, that is "ocean -nograph".
My conclusion is that used memories blow up if I use Cadence Skill in IC6.
I think this must be a critical defect of Cadence Skill in IC6.
« Last Edit: Feb 6th, 2018, 9:39pm by cheap_salary »
Reply #5 - Feb 8th, 2018, 12:59pm
That's a rather simplistic conclusion. It's not very likely to be SKILL itself that is the problem, but the objects being created not being garbage collected frequently enough.
Various types of objects are organised so that garbage collection is triggered when you run out of those objects, so it tries to do some housekeeping before allocating any more. It could be that your code is hanging onto objects which are no longer needed and thus preventing them being recycled, or it could be if this is waveform data that it is being cached to improve performance. You still read waveform data if you're doing simulation post-processing and not plotting anything; the caching occurs to improve performance if you access the same waveform more than once - we don't want to keep re-reading the same data from disk.
This is precisely why we (Cadence) need to see what you're doing - it's likely to be dependent on the nature of what you're doing rather than being something as simple as this being a "critical defect of Cadence Skill in IC6". Otherwise it would affect everyone, all the time. Which it doesn't.
cheap_salary
Reply #6 - Feb 9th, 2018, 3:07am
Andrew Beckett wrote on Feb 8th, 2018, 12:59pm:
I don't think so, since I use same skill code and same psf data for both IC5 and IC6.
I use only four work variables, "Vrec_out_Raw", "Ain0_dBV", "yyy" and "y".
So these work spaces have to be reused.
I do simulation as a completely another session, there I generate only psf data.
My skill script is for pure post processing without simulation.
I don't think so.
Simply no one do heavy post processing by skill code.
Vrec_out_x = 1.5
for(i, 1, 150
  sprintf(psf_dir, "results_dir_%d/pss", i)
  openResults(psf_dir)
  selectResult("pss_fd")
  Vrec_out_Raw = real( harmonic( v("vout"), 0 ) )
  Ain0_dBV = cross(Vrec_out_Raw, Vrec_out_x, 1, 'rising)
  fprintf(fp, "%g", Ain0_dBV)
  selectResult("pss_td")
  for(k, 1, 200
    sprintf(yyy, "aho_%d:in", k)
    y = value( i(yyy), "Ain_dBV" Ain0_dBV )
    fprintf( fp, ",%g", average( abs(y) )/1m )
    sprintf(yyy, "boke_%d.Vb", k)
    y = value( v(yyy), "Ain_dBV" Ain0_dBV )
    fprintf( fp, ",%g", ymax(y) )
  ); for k
  when( dbGetDatabaseType() == "OpenAccess", closeResults(psf_dir) )
  fprintf(fp, "\n")
  drain(fp)
); for i
close(fp)
exit()
I can complete this code by Skill in IC5.
But I can not by Skill in IC6.
If loop is small, e.g. " for(k, 1, 10" instead of " for(k, 1, 200" , I can complete even by Skill in IC6.
BTW, "closeResults(psf_dir)" is available in OCEAN in IC6,
but it is not helpful at all.
« Last Edit: Feb 9th, 2018, 9:54pm by cheap_salary »
Reply #7 - Feb 18th, 2018, 1:34am
Of course, nobody has written any SKILL code in the last 12 years (since IC6.1.0 was released) which does any heavy processing. What a ridiculous statement.
I'm afraid you're incorrect about this being a critical defect in SKILL. What it's likely to be (as I said before) is something that is not freeing a cached waveform object. This is not necessarily related to the variables you're using in your script. It's likely to be related to the fact that you are reading 150+150*200*2 signals (60150) and there's also another temporary waveform created in the inner loop (150*200) for the abs function.
Yes, of course these should be garbage collected and the memory re-used, but there is a tradeoff to be had with respect to signals read in from disk - you don't want to have to keep reading the same data off disk over and over again, which happens surprisingly often. This is why you should report this to Cadence with the data and your script so that R&D can take a look and see if any of the recent improvements help - or if something else needs to be done to prevent memory being exhausted. Quite likely there is.
However, as I said before - this is not a critical defect in SKILL itself. You're conflating correlation and causality. It's due to a change in how waveform objects (in ViVA) are handled in Virtuoso between IC5 and IC6 - there are lots of other benefits of this change (performance in particular) but with all implementations there are tradeoffs, and clearly in this case there is the opportunity (if you report it) to improve that tradeoff in the specific situation you're facing.
cheap_salary
Reply #8 - Feb 18th, 2018, 1:44am
Andrew Beckett wrote on Feb 18th, 2018, 1:34am:
Right.
Right.
However "closeResults(psf_dir)" should release memories.
"closeResults(psf_dir)" was introduced in IC6 which does not exist in IC5.
But it is no meaning at all.
Conclusion is that skill in IC6 consume very large memories than IC5 and never release them.
http://www.designers-guide.org/Forum/YaBB.pl?num=1513431975/0#0
So we have to make one session of skill very small in IC6.
However ability of treatment is too small in IC6.
Due to this limitation, ADE-XL, ADE-GXL and ADE-Explorer assume to use multiple sessions of skill.
« Last Edit: Feb 18th, 2018, 3:05am by cheap_salary »
Reply #9 - Feb 18th, 2018, 1:54pm
Again, you're drawing conclusions based on incorrect assumptions.
  • The purpose of closeSession is to free up the ADE session (and release the license); the goal is not necessarily to free memory (although this might be a side benefit of a recent improvement in the latest versions of IC617 - not sure if it helps your case though, hence the request to go to customer support). Might be worth checking with IC617 ISR17 first, although I can't guarantee that will help solve your problem.
  • ADE XL, Explorer and Assembler do not make any assumptions about using "multiple sessions of skill". They actually use several ICRPs (the background process used in ADE XL, Assembler and Explorer) in order to process in parallel (parameterisation, netlisting, simulation control and post-processing). It's not done for memory reasons.
  • It certainly does re-use memory for waveform objects in many cases given the kind of processing that many ADE users do, but clearly that's not happening properly in your specific case.
Have you actually contacted Cadence customer support over this issue?
cheap_salary
Reply #10 - Feb 18th, 2018, 4:52pm
Andrew Beckett wrote on Feb 18th, 2018, 1:54pm:
Wrong.
I use closeResults() which are introduced in IC6.
Reply #11 - Feb 19th, 2018, 3:11am
Quote:
Wrong.
My mistake. I misread closeResults as ocnCloseSession (shows the dangers of responding when  you're on vacation and so I wasn't checking carefully enough).
I've done a bit of experimentation (now that I'm back at work) and I don't think closeResults() or ocnResetResults() are properly returning the memory to the pool (note, the memory may not be freed back to the OS, but at least Virtuoso should be able to re-use it for other waveform objects).
It's not clear from reading through the original request for closeResults() whether it was implemented with freeing memory in mind, although that seems to me a very good idea. It was mostly about closing any objects (and in particular file handles) so that psf directories could be deleted on disk.
So as I suggested, you should contact Cadence customer support about this (closeResults() should free memory used by any waveform objects which are no longer referenced via variables). I can raise it internally, but it's likely to get prioritised if coming from a real customer.
Reply #12 - Feb 19th, 2018, 5:00am
A workaround seems to be to force a garbage collection after the call to closeResults() by calling gc() .
I had a discussion with R&D today (I filed an internal CCR 1881844 to suggest improving closeResults()). So it would be worth mentioning that if you log a case with customer support.
I'd be interested in hearing if calling gc() in your code improves matters.
Reply #13 - Feb 19th, 2018, 10:33pm
It would also help to know how large the time domain data is in terms of the number of points. I suspect there must be a lot of points as otherwise 60,000 waveforms shouldn't be enough for excessive memory usage (I also would expect that number of waveforms to trigger garbage collection, probably). I'd like to try to reproduce some data with the characteristics of what you're seeing (logging a case with Cadence Customer Support would be best, but knowing this is better than nothing).
So after the line:
can you add:
  printf("Number of points: %d\n" drVectorLength(drGetWaveformXVec(v("boke_1.Vb"))))
That said, I have just realised (from looking at your script) that there's presumably a sweep around the pss in your setup because of the value() statements. So instead of above, I might need:
  printf("Sweep values: %L\n" sweepValues())
  sprintf(yyy, "boke_1.Vb", k)
  printf("Number of points: %d\n" drVectorLength(drGetWaveformXVec(y)))
cheap_salary
Reply #14 - Feb 20th, 2018, 2:41am
Andrew Beckett wrote on Feb 19th, 2018, 10:33pm:
Same problem occurs even if I only use "pss_fd".
Actually, this thread starts for post processing of only "pss_fd".
Andrew Beckett wrote on Feb 19th, 2018, 5:00am:
I have to get post processing results, so I use IC5 OCEAN for a while, since I can not get results at all by IC6 OCEAN.
Later I will confirm "gc()".
Pages: 1 2
