Andrew Beckett wrote on Feb 19th, 2018, 5:00am:I'd be interested in hearing if calling gc() in your code improves matters.
gc() is not helpful at all.
Code:\# Memory report: using 301 MB, process size 1,405 MB at UTC 2018.04.09 00:50:43.056
\# Memory report: using 830 MB, process size 1,933 MB at UTC 2018.04.09 00:50:50.018
\# Memory report: using 1,368 MB, process size 2,472 MB at UTC 2018.04.09 00:50:50.465
\# Memory report: Maximum memory size now 47,998 MB at UTC 2018.04.09 00:50:51.508
\w *WARNING* Low Memory: Less than 1903 megabytes of system memory remain available to this program (3.9456% of a maximum of 47.1 gigabytes).
\w *WARNING* Low Memory: No further low memory warnings will be output.
\# Available memory: 3,971 MB at UTC 2018.04.09 06:55:25.431
\# Available memory: 2,785 MB at UTC 2018.04.09 07:08:12.687
\# Memory report: using 47,612 MB, process size 48,715 MB at UTC 2018.04.09 07:08:12.863
\# test ***warning***: memory usage seems to be dangerously high.
\# Memory report: using 47,612 MB, process size 48,716 MB at UTC 2018.04.09 07:09:57.267
\w *WARNING* Swap Activity: Excessive swap activity has been detected, which can cause decreased performance. The application will continue to run, but if excessive swapping continues
\w *WARNING* Swap Activity: due to the memory requirements of all the programs currently running on this system, the performance of this program may continue to be negatively affected.
\# Memory report: using 48,070 MB, process size 49,174 MB at UTC 2018.04.09 07:25:37.283
\# Available memory: 1,909 MB at UTC 2018.04.09 07:34:01.053
\# Memory report: using 48,315 MB, process size 49,418 MB at UTC 2018.04.09 07:34:01.053
\# Memory report: using 48,322 MB, process size 49,425 MB at UTC 2018.04.09 07:34:02.100
\# Memory report: using 48,331 MB, process size 49,434 MB at UTC 2018.04.09 07:34:06.139
Ocean died at this point.I have to use Skill in IC5.
