Jul 4th, 2025, 4:01am
Pages: 1 2
Virtuoso Slow Down after Large Memory exhaustion (Read 4735 times)
Re: Virtuoso Slow Down after Large Memory exhaustion
Reply #15 - Feb 20th, 2018, 3:28am
Thanks.
When you have a moment, I'd really appreciate knowing some more details on the characteristics of your data size (as I requested) as well as whether gc() helps, as this will help understand why automatic garbage collection is not working in your case. Of course, the real life design work comes first!
Reply #16 - Feb 23rd, 2018, 6:27am
A bit further information. I decided to try to reproduce a similar scenario to yours (with a bit of guess work on the sizes of the data that would be enough to show the problem). I picked about 1000 points in the time-domain results, and 20 points in the sweeps around the pss.
With this, I see the problem you're facing. Also, in this case gc() does help a bit, but not hugely (it reduces the memory footprint to 75%-85% of the memory footprint without the gc() calls). I do see evidence of garbage collection being performed during the script run - but the memory continued to grow (up to about 12Gbytes in my example - the amount would depend on the number of sweep points and time points). I was using a script that was a modified version of yours.
Anyway, I've passed this onto R&D - we need to identify what in the ViVA result management is not re-using memory, and this example is probably good enough to do it. Simply calling gc() as part of closeResults() won't solve the problem - it really helped in my other example which had a relatively small number of very large signals - but clearly doesn't help so much in the situation where you have a lot of medium-sized signals.
It would still make sense to log a case with Cadence customer support and have them file a duplicate of CCR 1881844 so that it has the weight of a customer request behind it.
Kind Regards,
cheap_salary
Reply #17 - Apr 9th, 2018, 6:53am
Andrew Beckett wrote on Feb 19th, 2018, 5:00am:
I'd be interested in hearing if calling gc() in your code improves matters.
gc() is not helpful at all.
\# Memory report: using	   301 MB, process size 1,405 MB at UTC 2018.04.09 00:50:43.056
\# Memory report: using	   830 MB, process size 1,933 MB at UTC 2018.04.09 00:50:50.018
\# Memory report: using	 1,368 MB, process size 2,472 MB at UTC 2018.04.09 00:50:50.465
\# Memory report: Maximum memory size now 47,998 MB at UTC 2018.04.09 00:50:51.508
\w *WARNING* Low Memory: Less than 1903 megabytes of system memory remain available to this program (3.9456% of a maximum of 47.1 gigabytes).
\w *WARNING* Low Memory: No further low memory warnings will be output.
\# Available memory:	    3,971 MB at UTC 2018.04.09 06:55:25.431
\# Available memory:	    2,785 MB at UTC 2018.04.09 07:08:12.687
\# Memory report: using	47,612 MB, process size 48,715 MB at UTC 2018.04.09 07:08:12.863
\# test ***warning***: memory usage seems to be dangerously high.
\# Memory report: using	47,612 MB, process size 48,716 MB at UTC 2018.04.09 07:09:57.267
\w *WARNING* Swap Activity: Excessive swap activity has been detected, which can cause decreased performance.  The application will continue to run, but if excessive swapping continues
\w *WARNING* Swap Activity: due to the memory requirements of all the programs currently running on this system, the performance of this program may continue to be negatively affected.
\# Memory report: using	48,070 MB, process size 49,174 MB at UTC 2018.04.09 07:25:37.283
\# Available memory:	    1,909 MB at UTC 2018.04.09 07:34:01.053
\# Memory report: using	48,315 MB, process size 49,418 MB at UTC 2018.04.09 07:34:01.053
\# Memory report: using	48,322 MB, process size 49,425 MB at UTC 2018.04.09 07:34:02.100
\# Memory report: using	48,331 MB, process size 49,434 MB at UTC 2018.04.09 07:34:06.139
Ocean died at this point.
I have to use Skill in IC5.
Reply #18 - Apr 17th, 2018, 12:46am
Thanks for confirming - that doesn't surprise me given that my attempt to replicate what I guessed was your structure from what you had described led to a similar conclusion; I found that repeatedly calling gc() during the loops slowed the memory growth a bit, but not massively.
It still would be best if you report this to Cadence customer support, referencing the CCR I mentioned above. Having to use a long-unsupported version of the tools is not a sustainable solution. Then we can work out how best to optimise the ViVA memory usage so that it doesn't exhaust the memory (as I said before, this is a tradeoff between avoiding unnecessary re-reading of results over and over again and consuming memory, but that trade-off needs to be adjusted based on what you and I are seeing here).
Kind Regards,
Pages: 1 2
