Jul 23rd, 2024, 1:17am
BJT circuit:  Resistor to Voltage Converter (Read 1061 times)
luoshuer
Feb 19th, 2018, 6:04pm
Hi Guys
I am not an expert in bipolar circuit design. Currently, I am working on the bipolar circuit, resistor to voltage converter, and looking for the help.
External resistance ranges from 100 to 10K, output voltage is around +/- 100mV @ 40C from 100 to 10K.  The output could be slightly off from the picture, and I am looking for a conceptual solution
Many thanks indeed
Suer
A Kumar R
India
Re: BJT circuit:  Resistor to Voltage Converter
Reply #1 - Feb 20th, 2018, 3:32am
you have a negative supply in the system?
luoshuer
Reply #2 - Feb 20th, 2018, 9:28am
Hi Kumar,
I have VDD= 2V, GND=-1.3V
Sorry, I didn't mention it earlier.
Raymond
Jacki
Reply #3 - Mar 20th, 2018, 1:39am
which kind of help do you need? a resistor to voltage converter seems like a resistive sensor, with the voltage divider and voltage buffer, you track the output voltage. I think if you want a good track, first your supply votlage should be quite stable, or else, you need a Vref. The bipolar transistor may help you to generate the Vref, maybe the buffer as well. The output voltage accuracy depends on the sensitivity requirement of your sensor.
