Sep 20th, 2026, 2:58pm
Why do we need CDS, not only use auto-zero instead? (Read 2871 times)
Jacki
Feb 28th, 2018, 11:42pm
   Recently I recall the definition of correlated double sampling and auto-zeroing, i find it is not necessary to use CDS, we can just use auto-zeroing instead. Here we don't discuss the chopping.
   For example, in the switched-capacitor amplifier, we can use capacitive reset instead of opamp reset to achieve the auto-zeroing. But if we want to use the CDS, we have to either add more capacitors or change the switching solution (for example the CDS integrator).
   My first question is now that we can use auto-zeroing to achieve the offset cancellation, why we need CDS?
   My second question is when we use CDS, the opamp should have lower thermal noise, why? If the CDS is normally used in oversampling, maybe it is better for the fast response at the output than auto-zeroing.
   Any comments? Correction? Thank you very much.
Jacki
Re: Why do we need CDS, not only use auto-zero instead?
Reply #1 - Mar 11th, 2018, 4:26am
Can we say CDS is used for high-speed application compared with auto-zeroing?
