Apr 29th, 2024, 11:35pm
Differential current input amplifier (Read 1504 times)
ttwwjj
Mar 07th, 2018, 10:46pm
Hi guy,
I saw this amplifier at work and a text book.
My textbook just claims that it is good and try to use it without any detail analysis and references. Can anyone explain how it works or give any related references?
thx
Jacki
Re: Differential current input amplifier
Reply #1 - Mar 14th, 2018, 12:52am
I think it depends on your application, if you need a single-ended or differential current amplifier. The theory is basic current mirror, you keep the gate voltage stable for the four transistors, and input the signal voltage at the source. For common mode input voltage, the input impedance is very high, but for differential mode input voltage, the input impedance is 1/gm.
