Jul 24th, 2024, 9:21am
Pages: 1 2
Question about gyrator implementation of active inductor (Read 5144 times)
blue111
Re: Question about gyrator implementation of active inductor
Reply #15 - May 04th, 2018, 10:00am
Quote:
If you inject a current into node X, the feedback loop will respond to adjust the voltage on CL until the 2nd gm stage absorbs all of that current.  This gives you a low impedance at low frequencies.  How low?  Just 1/(gm1*rout1*gm2).  I.e. 1/total_gm.
I do not understand what you mean by "2nd gm stage absorbs all of that current"
blue111
Reply #16 - May 13th, 2018, 9:38am
blue111
Reply #17 - May 22nd, 2018, 8:04pm
Quote:
With the large transistor dimensions chosen in this design, the gyrator input-referred offsets are less than 6 mV
For https://cloudfront.escholarship.org/dist/prd/content/qt1pg6p6nb/qt1pg6p6nb.pdf?t... , how is large transistor dimension related to input-referred offsets ?
« Last Edit: May 22nd, 2018, 11:44pm by blue111 »
danmc
Boston
Reply #18 - May 23rd, 2018, 10:42am
google MOS transistor matching or look in any of the standard text books on analog circuit design about matching.  "Analysis and Design of Analog Integrated Circuits" by Gray&Meyer (now Gray, Hurs, Lewis, and Meyer) or really any of the others should have a discussion about this. I'm sure you can find many lecture notes online.
I'm curious as to what your application is for the gyrator?  Is this a class project?
blue111
Reply #19 - Jun 1st, 2018, 10:23pm
Do you guys have any idea how to select mosfet sizing of asymmetric differential pair (Gm2 transconductance circuit block) for maximum output impedance ?
I have derived the Rout expression at http://www.eevblog.com/forum/beginners/help-in-deriving-zin-small-signal-express...
Horror Vacui
Dresden, Germany
Reply #20 - Jun 5th, 2018, 1:29am
TLDR;
gm and output impedance can be separated. You can put cascodes to increase the output impedance, while the gm stays the same.
Pages: 1 2
